Hello C,
The problem you are having is probably due to the fact that when you configure one port, it resets the other. I�m attaching an example that shows how to configure all three ports without having them reset each other. The example sets them all the write, but should work when one is set to read.
If none of these suggestions help, or if I�m not correctly understanding your issue, please post the software and versions you are using, the applicable portions of your code, and any other information that may help, and I�ll be happy to look further into it.
Please let me know if this example doesn�t work for you, and have a nice day!
Robert M
Applications Engineer
Robert Mortensen
Software Engineer
