‎10-16-2006 08:48 AM
‎10-17-2006 04:35 AM
‎10-18-2006 04:14 AM
‎10-18-2006 04:31 AM
‎09-14-2010 11:51 AM
Hello there,
I am trying to synchronise two devices Daq Pad 6015. In NI E xamples Finder /Hardware input and output>>DAQmx>>Synchronization>>MultiDevice there are not any examples for this device.
Sarah, could you put some example code of synchronization of two Daq Pad 6015. I am using the PFI lines of the two devices, but I can´t obtain the synchronization.
Thanks.
Javo
‎09-16-2010 04:32 AM
Hello Javo,
This thread is over 4 years old. Please post a new thread. This will ensure that all members of the community can see it and can help you. In this new thread describe your exact hardware set up and Pins you have used to access the PFI lines. Any code you have written so far would also be helpful.
Sarah is not longer available to post on this forum.
