Multifunction DAQ
my-DAQ solution
Hello everyone. I have an issue using my-DAQ system. Right now I am working on some testing device. I have 7 RTD's and 2 Flow controller and 2 flow meters and 2 CO2 sensors. I have used 1 NI USB 6009 for 4 RTDs. Now I have no more space left to attach other sensors. So do I have to use 2 more NI 6009 or what should I do to acquire all the sensors data using one my-DAQ device. What are your suggestions as I have not much experience of electronics and NI data acquisition systems.
If I use 2 more DAQ cards then is there any way to connect all the DAQ cards at one computer port?
Or is there any NI device which I should purchase which has more analog inputs and outputs?
I shall be very thankful for your kind advice.
(2,078 Views)
Accepted by Rahman009
I'll suggest using NI USB - 6216.
By the link, you can find more information about the characteristics of devices.
Best regards
(1,900 Views)
