my parallel port scxi-1000 does not work in win2000
it works on one computer, but when i plug it to another computer i get (in max):
"device not responding to the selected base address.
would you like to continue anyway?"
the parallel port is in EPP mode, it prints, but this doesn't work...
setup:
Labview 6.0
NI-Daq 6.9.3
Max 2.2
SCXI-1000 (w/scxi-1200)
anyone have any ideas?
Thank you,
aaditya
(2,550 Views)
Aaditya,
What operating system are you using? Windows XP does not support the SCXI-1200. Also, if you are using Windows 2000, the parallel port is defaulted to not use interrupts. In order for the SCXI-1200 to work through the parallel port, interrupts must be enabled. Below is a doucument that contains more information:
Error "The device is not responding to the selected base address" When Using SCXI-1200 Connected Via...
I have also included another document that may provide a solution:
SCXI-1200 in MAX Returns "Not responding to select
ed base adress" after Assigning the Parallel Port ...
Finally, I have included the installation procedure for the SCXI-1200:
SCXI System Connected to Parallel Port Via SCXI-1200
Good luck with your application.
Spencer S.
(2,550 Views)
