External Scan Clock - acquire at fraction of external clock rate
"scan clock external - log scan at less than the external clock rate"
"I am using the Clock config vi to set the scan clock to external and connected to PFI0
PFI 0 is connected to a TTL level encoder, which is attached to the rotating shaft of a brake test dynamometer. The encoder provides 60 pulses per full rotation of the shaft. Thus I acquire 60 scans of the channels to the buffer for every turn of the shaft. So far, so good, this works fine.
However, I wish to use the same software on another dynamometer which is fitted with a different encoder. This encoder gives 1024 pulses per turn of the shaft. I do NOT want to acquire a scan for every pulse ( I don't want 1024 scans per turn of
thae shaft), I would prefer a 16th of this, say 64 scans per rotation. Can I use Clock config vi to set acquisition at some fraction of the external clock rate ?
I notice an example on your site describes setting the external channel clock to a fraction of the external clock, but I can't see anything similar for the scan clock."
(2,778 Views)
Hello Phil,
The solution is to use one of the on-board counters to act as a frequency divider for your external clock. You set it up for "pulse train generation" and wire your clock to the source of the counter. I have attached an example program that will do this part. Then combine this with one of the external clock analog input examples and you're in business!
I hope this helps!
Russell
http://www.ni.com/support
(2,778 Views)
Hi Russell,
Thanks for this suggestion, I will try it out at the first opportunity (within the next 48 hours).
I'll let you know how succesful it is. Max dynamometer speed is 2500rpm (i.e. (2500/60)x1024 pulses per sec from the encoder). So I guess the only issue will be whether the counter cope with 43KHz.
Many thanks
best regards
Phil
(2,778 Views)
Actually, the source of the STC counter can take up to 20 MHz!
--Russell
(2,778 Views)
