06-22-2004 08:51 AM
06-23-2004 05:24 PM
12-14-2006 12:56 AM
any one knows
that how to acquire data at 2Ms/s for 5min.
I tried with 6110
labview 8 , DAQ mx
using express vi's ,
but it saves a 3 sec or like that
Haider
12-14-2006 03:54 PM - edited 12-14-2006 03:54 PM
Message Edited by Zach Hindes on 12-14-2006 03:57 PM
12-17-2006 10:19 PM
1-- I have placed both Daq ASSt and Write file Vi inside the while loop and it continuous untill I press stop button. there is no delay vi
2---after I run for 5 min , some times it signals error
" unable to read all data .either decrease rate or increase buffer size may help "
after 5 min the data stores(text format) for only 3sec or 4sec or 10 sec randomly.
3--- your said sample to read =1/10 it will help me alot because i was triying randomly.
4-- how much should be buffer size if using tradional daq.
5---is there is any relation of "buffer size, samples to read at a time, rate," to samples=8192 as on user manual .
6----if I set rat 500ks/s and samples to read at a time =100k then it works fine and stores data for more than 5min ,but when I set rate 2Ms/s then it signals error and randomly saves the file for some times 2sec,3sec so not deterministic.
waiting for reply
Haider
12-17-2006 10:19 PM
waiting for reply
Haider
12-18-2006 03:34 PM
Hi Haider,
I’d really like to help you out, but it is in the best interest for you and the rest of the customers using these discussion forums to keep these questions confined to one thread. It looks like you’ve been posting the same questions to multiple forum threads.
Please do not continue to post in this discussion forum. I will be responding to your questions in the following thread.
How to acquire data at 2Ms/s using 6110
Thanks!
Ed W.
Applications Engineer
