ni 9213 multichannel slow sampling rate
Hi Mr--Smith,
This is an older thread and the original poster might not monitor it any more. If the error still occurs, could you make a new thread with as much information as you can give? What you're reading from, what type of data is coming in, what your code is doing and any of the error messages that pop up would all be helpful. It would get more traffic and we could troubleshoot exactly what you're experiencing in your code. We also like to have one thread per question. This also helps other users find an answer if they have similar problems.
Thank you,
-KP
Kurt P
Automated Test Software R&D
Message 11 of 13
(1,017 Views)
I think it is buffer overflow. Actually I still have problems. ..
When I start read data in NI 9213 but did not write to graph, same problems show up
Message 12 of 13
(1,012 Views)
Hey dragon-long,
In that case, it is definitely a good idea make a new thread and posts your code there. That thread will get more traffic than this one and it helps us track different errors that customers run into so we can improve our support.
Thank you,
-KP
Kurt P
Message 13 of 13
(1,003 Views)
