Multifunction DAQ
ni 9237 sampling rate
Hi All,
I am using a 9237 module for some load measurements. My experiments last along time and so I am generating a lot of data because of the minimum sampling rate.  I am having trouble setting an external timebase so I can lower my sampling rate to something more manageable?  Even just a sampling rate of 500 s/s would make a huge difference.
(3,888 Views)
Accepted by canisbellum
Hi cannisbellum,
As per the 9237 Specifications the minimum data rate range (fs) using internal master timebase is 1.613 kS/s and using external master timebase is 391 S/s. The easiest option would be to sample at 2kS/s and decimate your data by 4. This can be done using either "Decimate 1D Array" or "Decimate (Continuous).vi".
Valid Sampling Rates for the NI 9233, NI 9234, and NI 9237 - http://digital.ni.com/public.nsf/allkb/593CC07F76B1405A862570DE005F6836?OpenDocument
Best,
Carisa
Applications Engineer
(3,877 Views)
