Multifunction DAQ
ni 9265 no output
Trying to diagnose a lack of output on a NI 9265 20mA analog output board.  To do this, I've got...
 - 24VDC to Vsup & COM
 - DMM closing the loop AIx & COMx
 - Running Test Panel to adjust the output of a particular channel
When I change the output level on the Test Panel, I see a jump in mA, but it then returns to zero.  I'm expecting the mA output to stay constant and the prescribed level.  Isn't that how its supposed to work?
I see the same behavior when I run a simple AO VI to test the 9265 output.  That is, when I change the FP control input to the DAQmx write data,  I see a jump in the DMM mA reading, then return to zero. Not what I'm looking for.
Thanks for any input on this,
Greg
Greg R.
(3,305 Views)
Accepted by Greg_Reynolds
Any chance your DMM is set AC mA and not DC mA?
-AK2DM
(3,294 Views)
Good question.  I'm not that familiar with the DMM, but it did have a units reading mAAC.  That would explain it.  I'll check.
Greg
Greg R.
(3,288 Views)
Yes, that was indeed the issue.  When I switch to mADC mode, I get the output that I specify.
I did observe however that when I stop my DAQ task, the mA output stays on, even though I have a DAQmx Stop Task.vi after exiting the DAQ loop.  For my application, I want to return to 0mA or 4mA on exit.
Thanks for your help!
Greg
Greg R.
(3,278 Views)
Greg:
Add another set value function to 0 or 4ma outside the loop before the Stop Task.vi.
You're welcome!
-AK2DM
(3,254 Views)
Right, I thought of that too, and that works. But the DAQmx Stop Task function is to "return the state before the Start Task".  That's not happening.
Greg
Greg R.
(3,245 Views)
