ni 9265 no output
Trying to diagnose a lack of output on a NI 9265 20mA analog output board.  To do this, I've got...
 - 24VDC to Vsup & COM
 - DMM closing the loop AIx & COMx
 - Running Test Panel to adjust the output of a particular channel
When I change the output level on the Test Panel, I see a jump in mA, but it then returns to zero.  I'm expecting the mA output to stay constant and the prescribed level.  Isn't that how its supposed to work?
I see the same behavior when I run a simple AO VI to test the 9265 output.  That is, when I change the FP control input to the DAQmx write data,  I see a jump in the DMM mA reading, then return to zero. Not what I'm looking for.
Thanks for any input on this,
Greg
Greg R.
(3,302 Views)
Accepted by topic author Greg_Reynolds
Any chance your DMM is set AC mA and not DC mA?
-AK2DM
(3,291 Views)
Good question.  I'm not that familiar with the DMM, but it did have a units reading mAAC.  That would explain it.  I'll check.
Greg
Greg R.
(3,285 Views)
Yes, that was indeed the issue.  When I switch to mADC mode, I get the output that I specify.
I did observe however that when I stop my DAQ task, the mA output stays on, even though I have a DAQmx Stop Task.vi after exiting the DAQ loop.  For my application, I want to return to 0mA or 4mA on exit.
Thanks for your help!
Greg
Greg R.
(3,275 Views)
Greg:
Add another set value function to 0 or 4ma outside the loop before the Stop Task.vi.
You're welcome!
-AK2DM
(3,251 Views)
Right, I thought of that too, and that works. But the DAQmx Stop Task function is to "return the state before the Start Task".  That's not happening.
Greg
Greg R.
(3,242 Views)
