ni usb 6008 daq wrong voltage when using test panel
the pictures attached is how I connect the wire,  and the setting I used.  it suppose to get the value set in voltage output.,  instead I got value like in my opening post attachment
Message 11 of 15
(1,241 Views)
You are getting the same voltage in the read that you set with the write.
Message 12 of 15
(1,234 Views)
lol no, thats not mine. im trying to get the value like in the pics.
Message 13 of 15
(1,231 Views)
ok let me start over.
im using labview 2012 with max 9.6
attachment 1 is my wiring for ni usb 6008 daq
attachment 2 is the value i set
attachment 3 is the actual output i get which is wrong
hope this will clear it
Message 14 of 15
(1,227 Views)
Double check that there are no loose wires. Verify that you did not shut off the analog output when you moved to the analog in test panel (i.e. check with a dmm). Connect the analog out gnd to analog in gnd and try a RSE measurement.
Message 15 of 15
(1,203 Views)
