Multifunction DAQ
nidaqmx limit
Hi
I am trying to convert some nidaq code to nidaqmx code. As you can see in attached screendump I have a channeldefinition array and an array which defines the limits for these channels. They are put into the nidaq AIconfig vi which are perfectly happy about different limits for different channels.
Then I try to do the same in Nidaqmx using the DAQmx Create Channel and puts a list of channels into the vi. But this vi (DAQmx Create Channel) only acceps one min limit and one max limit which then are used for alle the channels.
The question is now, how do I create a tast with multiple channels which have different min and max limits??
(4,520 Views)
You can use a for loop with a shift register for the task and a create channel function inside the loop. The for loop will auto-index your array.
(4,510 Views)
So you mean I can add the channels one at a time in a for loop and thow the task id into the shiftregister?
(4,506 Views)
Accepted by JBM_DK
Yep.
GCentral
(4,502 Views)
