Multifunction DAQ
nidevmon.exe error 0xc0000142 / niusb6009 Multifunction I/O
Our Labview application collects analog data using a niusb6009 Multifuncion I/O. The application is proven, and has been in production for years.
Today, the application stopped receiving analog data. After shutting down the application, shutting down our computer w/ Windows XP Pro SP2.
The Computer and Windows was restarted. When opening our LabView Application, the following error was displayed:
nidevmon.exe Error: "The Application failed to initiate properly (0xc0000142) Click OK to terminate application.
(7,438 Views)
Accepted by SherwoodScubaSteve
Howdy Scuba Steve!
 Is there anything that could have been changed software/hardware-wise on the machine prior to this error occuring?  Also, what version of LabVIEW and DAQmx are you using?
 The nidevmon.exe error could be caused by a number of different things.  Please look over this KnowledgeBase article for possible solutions to the problem.
Barron
Applications Engineering
(7,414 Views)
this KB link no longer works.  can someone at NI please provide a new link to this KB article??
(3,419 Views)
Hey try the steps given in this KB: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P8iMSAS
If this step doesn't work then I suggest you uninstall and reinstall NI software.
(3,397 Views)
