04-21-2008 04:20 PM
04-22-2008 07:10 PM
Hi mcheatham,
Does this happen everytime you run your application or was this an isolated event? If it happens often try running an acquisition on the PCI-6220 using the test panel. This will remove your program from the equation and just test the driver installation and hardware. You can access the test panel for your card inside Measurement and Automation Explorer (MAX). MAX can be found under Start>>Programs>>Nationa Instruments>>Measurement and Automation. Once MAX is open you should find the PCI-6220 listed under Devices and Interfaces>>NI-DAQmx Devices. Right click and the PCI-6220 and select test panels. Setup the test panel with rates similar to your program. Let this run for several hours and see if it causes the computer to reboot also. Let me know if you have any questions and take care.
04-23-2008 08:55 AM
04-23-2008 11:05 AM
04-30-2008 10:11 AM
04-30-2008 10:53 AM
