outputting a file to digitial output
I'm kinda new to the use of Digital lines and Couters in the NI DAQmx environment and am seeking assistance.
I'm using the M-series PCI-6221 board with two 24 bit counters.
I'm using DAQmx 8.3, and I am programming in C++ using Microsoft Visual Studio .NET 2003.
The first set of questions are related to digital output (DO). I'd like to output a 1000 sample sequence, repeatedly.  The DO will be used to clock an external device.  My intention is to open a binary file (created in Matlab), copy its contents to an array, and play out the array values at 1000 Samples/sec. To accomplish this I first set-up a counter to generate a clock signal, using the 100kHz sample clock:
    DAQmxErrChk (DAQmxCreateTask("",&COHandle));
    DAQmxErrChk (DAQmxCreateCOPulseChanTicks(COHandle,"Dev1/ctr0","","100kHzTimebase",DAQmx_Val_Low,0,25,25));
    DAQmxErrChk (DAQmxCfgImplicitTiming(COHandle,DAQmx_Val_ContSamps,1000));
Then I set the DO to use this clock:
    DAQmxErrChk (DAQmxCreateTask("",&DOHandle));
    DAQmxErrChk (DAQmxCreateDOChan(DOHandle,"Dev1/port0","",DAQmx_Val_ChanForAllLines));
    DAQmxErrChk (DAQmxCfgSampClkTiming(DOHandle,"/Dev1/Ctr0InternalOutput",1.0,DAQmx_Val_Rising,DAQmx_Val_ContSamps,1000));
And finally I write out the 1000 samples in the array data:
    DAQmxErrChk (DAQmxWriteDigitalU32(DOHandle,2,0,10.0,DAQmx_Val_GroupByChannel,data,NULL,NULL));
My DO questions are:
1). Is DAQmxCfgSampClkTiming the appropriate way to set the DO clock source? It's behavior is a bit unexpected since, the value for the rate parameter (=1.0 in the code above), is irrelevant when I set the clock source to /Dev1/Ctr0InternalOutput.
2) Since I want to output the same DO sequence repeatedly, I assume my performance will be improved by not regenerating the data. How do I produce DO output without regeneration?
3) I'm not clear on the behavior of DAQmxWriteDigitalU32. Does the data array have to have values in bits, or in the final voltage output level? If the values are in bits what range of values will cover full scale?
The next set of questions are related to Counters. I want to use one of the counters to timestamp signals arriving on a digital input line
1) What DAQmx function should be used to set a counter's Gate and Source inputs?
2) Is the 100kHzTimeBase 'universal'? Meaning, if I use it for multiple tasks, will all tasks see the same clock signal, and therefore remain in sync?
Thanks for advice and comments.
Message 1 of 1
(2,951 Views)
