pci-5105 basic questions
I am using the PCI 5105 for triggering also.
I used an example from the NI find examples and I modified it. I want for each channel to have its own properties and to modify it as I want. It works for the vertical properties ( like the vertical range and vertical coupling) but it didn’t work for the horizontal properties ( like actual sample rate for each channel). Is there any ideas of how to do so?
Thanks a lot!!
Message 11 of 11
(294 Views)
