Multifunction DAQ
pci-6221 device naming in linux
If adding multiple boards in a Linux system how are the devices named?
(3,036 Views)
By default when you use the nidaqmxconfig utility to install/configure your DAQmx devices, they will be named "DevX," where X is the decided based on the order of installation. If you were going to be installing multiple PCI-6221s then they would be named Dev1, Dev2, Dev3, etc. There are a couple good developer zone articles that address this issue.
Chris
(3,025 Views)
