03-31-2009 02:14 PM
04-01-2009
08:53 AM
- last edited on
10-03-2025
09:39 AM
by
Content Cleaner
By default when you use the nidaqmxconfig utility to install/configure your DAQmx devices, they will be named "DevX," where X is the decided based on the order of installation. If you were going to be installing multiple PCI-6221s then they would be named Dev1, Dev2, Dev3, etc. There are a couple good developer zone articles that address this issue.
Chris
