pci-mio-16e-4 card not recognized
PCI MIO 16E 4 card not recognized in MAX 2.2, is there a driver or engine that needs downloading to run.
Windows 2000 see's board in device manager, no board in MAX!
(2,791 Views)
Hi Bacchea
If you see the board in the device manager (no conflicts) then I've to ask if you have refreshed MAX? If not, press F5 when MAX is the active window.
If you've already done this, thenI want to tell you what's the way to install NI-DAQ boards. I'm sorry if you alredy know that!
1. You need administrator rights.
2. Install NI-DAQ (reboot if asked). Board is not in the PC
3. Insert DAQ-board
4. Open MAX and press F5
That should work! By the way: Which NI-DAQ version are you using?
Luca
Luca
(2,791 Views)
NI-DAQ 6.9.2
(2,791 Views)
