can i generate two sinus to delay in phase in continue with the ni 6052E PCI
I want use the daq ni 6052 E in sinus generator
Channel 1 sin(x)
Channel 2 sin(x+pi/4)
continus generation without hole
How must I do
do it exist a VI
can you send me
Thank you
(2,558 Views)
Greetings,
Below is a link to a LabVIEW example that should accomplish the task you have described:
Generating Sine Waves Continuously on Two Analog Output Channels
Good luck with your application.
Spencer S.
(2,558 Views)
