Home
Community
Discussion Forums
Most Active Hardware Boards
Multifunction DAQ
Topic
Multifunction DAQ
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
can i generate two sinus to delay in phase in continue with the ni 6052E PCI
camille0190
Member
07-09-2003
08:33 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
I want use the daq ni 6052 E in sinus generator
Channel 1 sin(x)
Channel 2 sin(x+pi/4)
continus generation without hole
How must I do
do it exist a VI
can you send me
Thank you
0
Kudos
Message
1
of 2
(2,563 Views)
Reply
Re: can i generate two sinus to delay in phase in continue with the ni 6052E PCI
Spencer S.
Active Participant
07-11-2003
11:27 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Greetings,
Below is a link to a LabVIEW example that should accomplish the task you have described:
Generating Sine Waves Continuously on Two Analog Output Channels
Good luck with your application.
Spencer S.
0
Kudos
Message
2
of 2
(2,563 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
