06-09-2008 10:49 AM
06-10-2008 11:54 AM
Hi 0103536363
Could you kindly provide more informations on the source and type of signal you want to measure?
Is it that you just have a cDAQ module and you need help in configuring or programming the task? or simply you need a suggestion on how to perform a specific task and, thus, which module to use for that task?
Kind regards
Hudson | AE NIIT
06-11-2008 02:38 AM
in response your question, I have a signal by a pick-up, that shows a certain peak frequency.
The peak has a clear period, but it has different amplitude as voltage.
The signal isn’t a “correct”wave (as a square wave). Therefore, can I use all same time the module NI 9401?
Thanks for your answer!![]()
06-27-2008 08:16 AM
