pins on connectors
I have a NI 6014 card with 68 pins and want to connect it a 0.1in LATCHED HEADER - 2X25 WAY. I was wondering if anyone had any ideas as the card has a 5v supply while the connector is 12v
(2,612 Views)
If you have no need for the +/- 12 V connections, then you can certainly go without connecting them to anything and make measurements as you would otherwise. If you do need the voltage sources for your application, you will need to obtain them from some other source since the 6014 board will only provide +5 V.
(2,555 Views)
