please help with occupancy detection
Hi Everyone!!
I am trying to simulate an occupancy detection control using LABVIEW.  It uses 2 infrared sensors at 2 different horizontal distanceson the door!
If IR1 first detects the presence of the person followed by IR2, Entry is asserted and vice versa for EXIT!!
But my problem is "how to make LAbview detect the Delay od the 2 signals and respond accordingly!!
Please help guys. I have also attached a pic to get the prob more clear!!
(3,929 Views)
Hi Rishabh,
see the attached example. Maybe there is an easier way, but i didn't found it now.
Hope it helps.
Mike
Message Edited by MikeS81 on 07-29-2009 09:58 AM
(3,916 Views)
Mike,
Can you please post this for lv 8.0?
(3,912 Views)
Hi muks,
here it is.
@Rishabh
you should also add a timeout. Maybe someone enter IR1 but not IR2, then you have to reset the event from IR1 after some time.
Mike
Message Edited by MikeS81 on 07-29-2009 01:20 PM
(3,908 Views)
thanks mike
(3,904 Views)
