pmd1208
hi
i m using pmd1208ls . is it compactable with labview 8.5 evaluation version. i m not able to get libraries for this device in labview8.5
help me in thios regards
(3,758 Views)
That's from Measurement Computing isn't it? You need to get a driver from them.
(3,750 Views)
ntumuthu,
Do you already have libraries for this device for an older version LabVIEW? If you do, what is the problem, will the VIs not open in LabVIEW 8.5 at all, what seems to be the problem?
-Marshall R
(3,739 Views)
i m having lab view evaluation version only will it work on tat
(3,734 Views)
The evaluation version of LabVIEW is full featured. You can run anything you want for 30 days. You just can't use the built-in DAQ functions (i.e. DAQmx) because, obviously, you don't have an NI board. You just have to get a set of drivers from the vendor of your board.
(3,730 Views)
