problem on PXI6225
I have a PXI 6225 card with chassis system. There is a strange problem on this card. I open up the test panel of PXI6225 from MAX. And I try to test a few AI channel randomly. I picked up AI1, AI3, AI8. And I mannually apply some DC voltage on these channels. On the test panel, I choose one channel at a time, and choose one-time on-demand measuren with RSE mode. To my surprise, only AI8 work fine. AI1 and AI3 seems to add an offset to the actual voltage applied. For example, if I apply 0V on AI1 or AI3, it shows 3.5V. If I add 1V on them, it shows 4.5V, etc. Any idea on what is going on? Did I miss some setup to make it work correctly? Thanks.
Tieling
(4,122 Views)
Hey,
You could use the DAQmx Diagnostics Utility to check the card.
Christian
(4,107 Views)
In MAX, there is a selftest button for each device. I run that selftest for 6225. It passes. Does it mean it could still have problem on the card even if it passes the selftest? Thanks.
Alan
(4,103 Views)
Hi Alan,
The selftest is meant to solely communicate with the devices EEPROM and verify that it can communicate with the driver.  This is not a full test for the devices full functionality.  How do you have these voltages wired into the device?  Are you trying to read multiple channels simultaniously?
Regional Account Manager
NI
(4,095 Views)
I just apply a static voltage to that channel through a connector cable (SHC68-68, that is the accessory we bought). I only test one channel at a time. Any suggestion why it does measure the correct value?
Thanks.
(4,093 Views)
Hey,
Did you allready check with the diagnostics utility?
Christian
(4,088 Views)
Have not got a chance yet. But will do it probably next week, and then give you an update. Sorry for the delay because of tieing up with other stuff. Thanks.
(4,069 Views)
