Multifunction DAQ
problems with daqpad 6016
Using Labview 7.1.1 and NI-DAQmx 8.0.1 with a NI DAQPad-6016.
I'm having some problems.  I'm using the DAQPad for simple analog input measurements.  Well, at least I was, until LabVIEW began to lock up when trying to load VIs using DAQmx.  I dont believe that my code was a problem, because I was using an example VI.  It seemed to work for a while, but had a habit of crashing.  Then it just stopped working altogether.  The ready light will stay on, and the active light will blink every now and then, but I cant tell it to do anything, or even open measurement and automation explorer.  While it was working, I also noticed that it did something odd.  When I read from either of two channels, the measurements were around 3.5V.  When I read from both of them at the same time, both signals read 6.5-7.  Provided I can get DAQmx working again, with the DAQPad running stable, this will probably be a problem.
Let me know if I should provide anymore information, and thank you for any help you can offer.
(3,280 Views)
Well, I managed to get MAX and NI-DAQ working again by repairing their installation.  However, I am noticing a drift in my analog measurements.  I thought it may have been something off about one of the components I am using, but then I tried connecting the AI channel to ground, and the drift is still there.  Any tips?
(3,275 Views)
I managed to find a page that told me to short AI Sense to AI GND and use that with NRSE measurements, and the test panels look good, so time to start on my VI.
(3,269 Views)
