Using Labview 7.1.1 and NI-DAQmx 8.0.1 with a NI DAQPad-6016.
I'm having some problems. I'm using the DAQPad for simple analog input measurements. Well, at least I was, until LabVIEW began to lock up when trying to load VIs using DAQmx. I dont believe that my code was a problem, because I was using an example VI. It seemed to work for a while, but had a habit of crashing. Then it just stopped working altogether. The ready light will stay on, and the active light will blink every now and then, but I cant tell it to do anything, or even open measurement and automation explorer. While it was working, I also noticed that it did something odd. When I read from either of two channels, the measurements were around 3.5V. When I read from both of them at the same time, both signals read 6.5-7. Provided I can get DAQmx working again, with the DAQPad running stable, this will probably be a problem.
Let me know if I should provide anymore information, and thank you for any help you can offer.
