question about DAQ sampling rate
As you can see the screenshot below, why aggregate multichannel sampling rate is lower than single channel sampling rate?
(2,045 Views)
You have a device that is muxed. The A/D conversion is shared between all of the channels. You would need a card that has a separate A/D for each channel, like the 6366.
mcduff
(1,998 Views)
Hi Mcduff,
You didn't get what I mean. Even though sampling rate is shared by channels, but in principle the aggregate rate should be same as maximum single channel rate.
I searched similar question, seems reason is channel needs switching time for multichannels which sacrifice half sampling rate.
(1,989 Views)
Accepted by zyb1003
This may be helpful
https://www.ni.com/docs/en-US/bundle/ni-daqmx/page/multisimulsamp.html
Santhosh
Soliton Technologies
(1,968 Views)
