Multifunction DAQ
reccomend a card that can put out 0.66V sinusiodal signal at 1khz
Simple question that I'm sure any NI engineer can answer (and save me hours of research).  I need a board/usb system/whatever that can put out a 0.667 (2/3) volt sinusoidal signal at 1 kHz to run an opto-galvanic mirror.  Labview drivers are a must.
Thanks for any help!
(2,731 Views)
Depending on the resolution of the board and the type of features you want on the board, you are looking at a pretty wide array of devices.  Do you need USB form factor or does any form factor suit you?  If you are looking at USB specifically, you can reference the search I've done here.  For all DAQ devices that can do your output at the frequency listed, that search has been done here
The cheapest USB board is the USB-6211, cheapest PCI is the PCI-6221, and the cheapest PCIe is the PCIe-6321.
Kyle A.
Senior Applications Engineer
(2,709 Views)
