Multifunction DAQ
requested value is not a supported value for this property
Hi everyone,
I'm trying to use eletrophysiology software as WinEDR/WinWCP or GePulse, or any equivalente. I do have two NI card : NI PCI-6010 and NI USB 6008. My problem is that for both I get error message when I try to select interface in electrophysiology software like :
"requested value is not a supported value for this property"
or
"Error in n.DAQmxCfgSampClkTiming"
Is there any "simple" solution known .... ?
Thanks a lot !
dadep
(3,156 Views)
What values are you trying to set when you get that error?  My guess is you are trying to set the sample rate too high.
(3,147 Views)
I try to use this card as interface for the WinEDR software, but can't connect.... (in the software there is somewhere to choose interface).
When I use with our own script (in labview or matlab) it work fine
(3,145 Views)
