requested value is not a supported value for this property
Hi everyone,
I'm trying to use eletrophysiology software as WinEDR/WinWCP or GePulse, or any equivalente. I do have two NI card : NI PCI-6010 and NI USB 6008. My problem is that for both I get error message when I try to select interface in electrophysiology software like :
"requested value is not a supported value for this property"
or
"Error in n.DAQmxCfgSampClkTiming"
Is there any "simple" solution known .... ?
Thanks a lot !
dadep
(3,136 Views)
What values are you trying to set when you get that error?  My guess is you are trying to set the sample rate too high.
GCentral
(3,127 Views)
I try to use this card as interface for the WinEDR software, but can't connect.... (in the software there is somewhere to choose interface).
When I use with our own script (in labview or matlab) it work fine
(3,125 Views)
