sbRIO 9611
The page came with NI sb-RIO 9611 says "Go to ni.com/info and enter the info code sbriodocs to locate the user guide for this product"
But it is not there.
How to get started with this board? where are the documents? Smiley Frustrated
(4,417 Views)
(4,392 Views)
I have already gone through them,
Basically I am not getting few info ----- >
1> What is the Factory out IP address of this board?
2> Do I need any specific driver for this sb- RIO?
3> Which type of project should I start in LabVIEW to start programming (FPGA project? or anything else?)?
these are not there in those manuals!!
(4,370 Views)
Sounds like what you really want is the Getting Started With CompactRIO and LabVIEW guide. Should get you up and running, but I prefer the web portal experience at https://learn.ni.com/pages/getting-started. Just use the CompactRIO links (same requirements and setup).
To answer your questions directly:
  1. Should be set to DHCP (assuming it's a newer board), so it will acquire an IP when you connect it to your local network.
  2. Yup! You'll need NI-RIO. Which version will depend on which version of LabVIEW you're using. Here's the version compatibility chart.
  3. You should start learning LabVIEW RT first. Honestly, when you're ready to start your application, the Compact RIO Developers Guide will give you all the info you'll ever need. I recommend reading it cover to cover after going through the available (free with SSP) online training for LabVIEW RT and FPGA.
Cheers!
TJ G
(4,351 Views)
