selftest error -50204,file not found
hallo,
i want to install the ni daqpad-6015 on my computer. After connection and driver installation i like to test it with the measurement & automation explorer with the selftest function.
But there is the following error message
error -50204
possible reason: file not found
How can I solve the problem
Best regards
Filip Kubis
Message Edited by fkbs@de.festo.com on 02-28-2007 07:31 AM
Message Edited by fkbs@de.festo.com on 02-28-2007 07:32 AM
(3,449 Views)
Hello Kubis,
wich driver version do you use. Please update the DAQmx dirver.
Dirver update link: http://digital.ni.com/softlib.nsf/websearch/7FEAEE6A4B4AA836862571C00064E6CA?OpenDocument
Did you try to reset the device under MAX?
Kind regards,
Elmar
(3,428 Views)
after an update from 8.3.0 to 8.3.1 the problem solves itself.
Thanks and bye
F. Kubis
(3,425 Views)
