Home
Community
Discussion Forums
Most Active Hardware Boards
Multifunction DAQ
Topic
Multifunction DAQ
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
simultaneous circular buffered analog output and input using PCI 6115
efischer
Member
08-19-2003
04:51 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
i want to use circular buffered output and input with the ni 6115 and labview 6.1
does anyone know whats the best way to handle this.
any help will be appreciated
regards
erwin
0
Kudos
Message
1
of 2
(2,831 Views)
Reply
Re: simultaneous circular buffered analog output and input using PCI 6115
Spencer S.
Active Participant
08-20-2003
03:55 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Erwin,
I would suggest that you take a look at the examples available in the following location:
Examples >> Hardware Input and Output >> DAQ >> Simultaneous Analog IO
Specifically, you should examine
Simul AIAO Buffer(E-series).vi
and
Simul AIAO BufTrig(E-series).vi
If you are interested in synchronizing the input and output operations, the examples linked below will demonstrate the proper programming techniques:
Simultaneous Analog Input and Output (E Series Board)
Synchronizing Simultaneous Analog Input and Analog Output on Multiple Channels
Good luck with your application.
Spencer S.
0
Kudos
Message
2
of 2
(2,831 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
