slew rate NI-7831R = 0.7V/us
Hi
I'm using analog output of the NI-7831R with your example "Analog output.vi" in the folder "Rseries examples". So I'm measuring by means of a oscilloscope the slew rate when I change the voltage value, and I obtained 0.7 V/us, however in the user manual appears 10 V/us.
Any idea about this?
Thanks in advanced.
(3,125 Views)
Any possible charging on your oscilloscope probe?
Yik
Kudos and Accepted as Solution are welcome!
(3,025 Views)
No, because I checked it with other instruments generating the signal and the same oscilloscope probe and I measured slew rate faster than I get with the NI-7831R.
(3,010 Views)
