PCI6221 & SC2345 Analog input acquisition without SCC module
I'm using a PCI6221 & SC2345. SC2345 has 20 slots for SCC modules out of which I'm using only 4. I want to use the rest of the analog inputs of the PCI6221 without SCC. Where to connect the signals?
Rgds,
Giridhar
NextFirst Engineering Technologies
(3,917 Views)
Hello, someboady please help me with this. Thanks.
(3,841 Views)
Hello, somebody please help me with this. Thanks.
(3,840 Views)
Hello Giridhar,
In order to use the Analog input lines of the DAQ card without signal conditioning, you would need to use the scc-ft01. This will feed through the signals without signal condidtioning. However this is a SCC module and there is not much we can do without these modules on the SC2345.
Mithilesh
(3,793 Views)
