strain gauge calibration problem
Sirs,
I am work on strain gauge matters measurements using a strain 120 Ohm connected to the NI9944 to build the half bridge that goes inside the 9237.
I am using:
1. NI cDAQ 9178
2. NI 9273
3. NI 9944
I am using the same program that is given in here :  https://decibel.ni.com/content/docs/DOC-11148
But I have a  problem with the strain calibration, its show an Error 200077 when I try to calibration in the program. I have attached the Image of it.
When I put those values(as soon in the error) in the range(Max & Min) It again shows the same error but this time some different range.
I am also using the DAQ Assistance which work just fine with the calibration for the same connection of strain gauge.
Please help me out here, What ? I am missing
Thank you
Message 1 of 1
(3,107 Views)
