10-26-2012 11:32 AM
I am generating a waveform from a function generator into my NI USB-6259 multifunction DAQ. For the life of me I can't figure out how to get the waveform data of the input voltage samples using the C functions. I am able to read the actual sample voltage values but which function can I use to get the corresponding sample clock values?
10-29-2012
06:00 PM
- last edited on
02-19-2026
11:50 AM
by
Content Cleaner
Hi brianbat,
There are multiple examples are shipped with LabVIEW which may help you with this application. For more information, see the following link: https://www.ni.com/en/support/documentation/supplemental/21/using-ni-daqmx-in-text-based-programming...
Hope that helps!
