How do I get analog input waveform data using C functions?
I am generating a waveform from a function generator into my NI USB-6259 multifunction DAQ.  For the life of me I can't figure out how to get the waveform data of the input voltage samples using the C functions.  I am able to read the actual sample voltage values but which function can I use to get the corresponding sample clock values?
(3,363 Views)
Hi brianbat,
There are multiple examples are shipped with LabVIEW which may help you with this application.  For more information, see the following link: https://www.ni.com/en/support/documentation/supplemental/21/using-ni-daqmx-in-text-based-programming...
Hope that helps!
Patrick W.
(3,336 Views)
