Multifunction DAQ
subtract some amount form acquired data
Hi
Thanks for the reply. I couldn't find any examples with custom scale in it. Could you tell me if you know? I am using labview 8.2.
Message 11 of 13
(998 Views)
I don't know of a specific example either. Do you get an error when you run the VI or not? If you do, what's the code. If you don't get an error, you might want to connect the error clusters of the scale functions like shown earlier.
Message 12 of 13
(988 Views)
Hi dennis
Thanks for the reply. I wired error from daqmx create channel vi to custom scale vi  then to daqmx create channel for the second channel. Then it worked fine.
Message 13 of 13
(960 Views)
