sync of two daq assistants
Attached is a example vi i am trying to make work.  I have two DAQ assistants inside the loop, one analog out and one analog in.  I need the input to start recording data before the output sends out the next sample and I dont know how to sync them.
any ideas.
(3,147 Views)
You could try using a sequence structure with a Wait in the first frame and the DAQ Assistant that is generating in the second frame. This will delay it from generating for the amount of time specified. I have attached a simple screenshot show this.
Chris Delvizis
(3,131 Views)
