type initializer for 'NationalInstruments.PrecisionWaveformTiming' threw an exception
I try to scan three channels (ai0-2) with a PCIe-6361 card on a Windows XP SP3 PC with Visual Studio 2010 Prof and .Net-Framework 4.The exception occurs when I call the line:
data = reader.ReadWaveform(Anzahl_Werte_per_Chan)
It is the same, when I try to scan only one channel, so it looks like a general thing.
Any idea? Any help? Thanks a lot!
Axel
error message says:
"The type initializer for 'NationalInstruments.PrecisionWaveformTiming' threw an exception."
Code is:
sampleRate = 300000
Kanal1 = "Dev1/ai0"
Kanal2 = "Dev1/ai1"
Kanal3 = "Dev1/ai2"
Anzahl_Werte_per_Chan = 100000
    Sub Sample_3_Channels(Soll_SampleRate As Double, ByRef Ist_Samplerate As Double, Kanal1 As Integer, Kanal2 As Integer, Kanal3 As Integer, Anzahl_Werte_per_Chan As Int32, ByRef Messwertfeld_1() As Double, ByRef Messwertfeld_2() As Double, ByRef Messwertfeld_3() As Double, ByRef Errnum As Integer)
        Dim Device_String As String
        Errnum = 0
        If gOhne_NI = True Then Exit Sub
        Try
            ' Create a new task
            myTask = New Task()
            Device_String = ""
            Device_String = "Dev" & Format(gNI_Device, "0") & "/ai" & Format(Kanal1) & ","
            Device_String = Device_String & "Dev" & Format(gNI_Device, "0") & "/ai" & Format(Kanal2) & ","
            Device_String = Device_String & "Dev" & Format(gNI_Device, "0") & "/ai" & Format(Kanal3) & ","
            ' Create a channel
            myTask.AIChannels.CreateVoltageChannel(Device_String, "", AITerminalConfiguration.Rse, -10, 10, AIVoltageUnits.Volts)
            ' Configure timing specs
            myTask.Timing.ConfigureSampleClock("", Soll_SampleRate, SampleClockActiveEdge.Rising, SampleQuantityMode.FiniteSamples, Anzahl_Werte_per_Chan)
            ' Verify the task
            myTask.Control(TaskAction.Verify)
            Ist_Samplerate = myTask.Timing.AIConvertRate / 3.0
            reader = New AnalogMultiChannelReader(myTask.Stream)
            ' Read the data
            Dim data() As AnalogWaveform(Of Double)
            'For Each waveform As AnalogWaveform(Of Double) In data
            Dim dataCount As Integer = 0
            dataCount = data(0).Samples.Count
            ReDim Messwertfeld_1(0 To (dataCount - 1))
            For sample As Integer = 0 To (dataCount - 1)
                Messwertfeld_1(sample) = (data(0).Samples(sample).Value * g_AI(Kanal1).Gain - g_AI(Kanal1).offset)
            dataCount = data(1).Samples.Count
            ReDim Messwertfeld_2(0 To (dataCount - 1))
                Messwertfeld_2(sample) = (data(1).Samples(sample).Value * g_AI(Kanal2).Gain - g_AI(Kanal2).offset)
            dataCount = data(2).Samples.Count
            ReDim Messwertfeld_3(0 To (dataCount - 1))
                Messwertfeld_3(sample) = (data(2).Samples(sample).Value * g_AI(Kanal3).Gain - g_AI(Kanal3).offset)
        Catch dex As DaqException
            FehlerLog(True, dex)
            Errnum = -1
        Catch ex As Exception
            FehlerLog(True, ex)
            Errnum = -1
        Finally
            myTask.Dispose()
        End Try
(4,114 Views)
I forgot: NI-DAQmx Version 9.4.0.f5. Meanwhile I believe that the project references are not correct or the DAQmx driver is not installed correct (or a part is missing).
Any idea? Thanks in advance!
Axel
(4,109 Views)
Hi Axel,
Where does this error occur?
On your development pc or is it an application?
Have you already tried this Knowledge Base?
System.TypeInitializationException Error When Loading a Deployed Measurement Studio Analysis Application
http://digital.ni.com/public.nsf/allkb/70648C253C7155FD862570ED005EA94E?OpenDocument
(4,097 Views)
Hi ZwJoh,
thanks for your answer. Meanwhile I found a similar possibility. I think the custumer doesn't install the files for the .Net Framework 4, he simply choose "typical installation". So I tried to modify the installation, but the installer showed an error message (see attached file). I didn't find a way to get the installation work and the error occurs for all kinds of .Net Framework versions. Any idea what to do?
Thanks in advance for any hint!
Axel
(4,085 Views)
Hi ZwJoh and all others,
I have the same problem on the developer system as on machine. But I did a mistake. I tried to install the complete .Net Framework 4 support. On my system it was enough to install only the support without the sub-features. Maybe that solves everything?
Thanks for any help anyway.
Axel
(4,081 Views)
