usb-6009 daq 2 inputs
Hello
I am currently using a usb-6009 with labview 7.1 and DAQmx 8.1 to read data into a LVM file at a sample rate of 40kHz.  Everything is working perfectly when I'm only reading one channel.  Problem is I need to read 3 channels and when I set the DAQ assist to read 2 channels, the max sample rate is 24kHz, which is not sufficient for the problem.
I then thought that I could manage by just reading one channel at a time at 40kHz(using digital input to determine which channel).  Is this possible?  When I set up the DAQ assistant with more channels, I am unable to select a 40Khz sample rate.  I know you can't open multiple DAQ assistant for analogue inputs, so I tried to overcome this by creating a main program with subprograms, each using one DAQ assists, but still got the error:  "The specified resource is reserved. The operation could not be completed as specified.".
I tried to set it up without the DAQ assist, but got an error: Task specified is invalid or does not exist"(error code 200088) which seem to be a known an unfixable problem on labview 7.1. (also I am guessing I will get the same error of the resource is reserved as I did in DAQ assistant)
Is there any way I can set up one program to read an analogue input at 40kHz on one channel and then switch to another channel and do the same?
Herman
(4,205 Views)
Accepted by topic author Herman Malan
Sure, but you have to stop and clear the previous task before starting a new one. You obviously have not done that since you are getting that error.
(4,195 Views)
Thanks, that did the trick.  I previously only set a stop task function.
You'll have to forgive me for my stupid mistakes, I've only been using LV for about 3 days, really appreciate the help.
Herman
(4,173 Views)
Where is the solution to this
(3,590 Views)
The solution is described above. I don't know what else you might want.
(3,574 Views)
