usb-4065 softpanel issue
i just installed all the drivers for the USB-4065 DMM, but when i boot up the soft panel error messages popup saying
"Labview: Resource not not found.
nimaglvu.dll
An error occurred loading VI 'maglvHashDelete.vi' " and other vi's with this sam dll error
(6,085 Views)
When you say 'all the drivers' what drivers are you talking about?  Have you tried repairing the DMM driver?  What version of NI DMM did you download?  What is your OS version and other versions, such as LabVIEW, are you using?
Jonathan R.
(6,041 Views)
Accepted by topic author Ccyclone128a
i recently just uninstalled all NI software and re-installed my (NI-VISA 15.5 + NI-DMM 15.2) and now it is functional thanks.
As for the Labview i'm using 2015.
(5,996 Views)
Great to hear.  If this forum is resolved please label it so.  As for future reference if you need to troubleshoot such issue it is a good idea to first try to repair the drivers/software in question.  If that doesn't work then a force reinstall instead of an uninstall and reinstall is more ideal so you can minimize registry corruption, it will be faster, and tends to patch over issues from the original install:
How to Uninstall or Repair
https://www.ni.com/en/support/documentation/supplemental/18/uninstall-or-repair-national-instruments...
Force Reinstall NI Software
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YGwJCAW&l=en-US
Jonathan R.
(5,983 Views)
Jonathan,
I too am having a soft panel issue with a usb-4065.
Setup:
I've downloaded and installed NIDMM1750.exe onto a windows 10 laptop...during install I've selected all support features.  There are no other NI applications installed on this laptop.
Issue:
After install and reboot and updates, I plug in the usb-4065.  The windows task bar notification informs me that it have installed the drivers and is ready to use.  I can run NI MAX and the usb-4065 shows up under "Devices and Interfaces".  Both the "Reset" and "Self-Test" functions come back with a success notification.  When I try to open the Test Panel from NI MAX, I get the following error:NIDMM.pngNIDMM.png
However, if I open the Windows Start menu and select NI-DMM Soft Front Panel it works perfectly.
On my LabView development system the soft panel works from NI MAX.  On my PXIe systems, the soft panel works from NI MAX.
Is there a specific reason I cannot launch the usb-4065 soft panel from NI MAX on this Window10 laptop?
Please let me know what process I need to go through to allow the soft panel to launch from NI MAX when installing NIDMM1750.exe on a clean WIN10 laptop.
Thank you for your time.
Danny W
(4,776 Views)
Hi Danny,
First, this post is around 2 years old so I would recommend creating another request and reference to this one so it can get more views.
Second, have you tried to force reinstall the software like Jonathan suggested?
Lastly, I might try to reset the MAX database.
Hopefully one of those steps works, but again I would still recommend creating another post so it can get more views.
(4,747 Views)
