usb-6008 LabVIEW 2011
Hello there,
I don't find any solution to make my usb-6008 usb interface work on LabVIEW 2011, the DAQmx Assistant is away and I don't find any comparable VI's!
Anyone any idea?
Simon
(4,039 Views)
Accepted by simon_brieden
Did you install the DAQmx driver after installing LabVIEW?
(4,035 Views)
Yeah I did, but old ones, thought I had the newest... called the support and they told me to install the new drivers. Thanks for your help 🙂
Simon
(4,014 Views)
I have the same problem I'm not able to use my USB-6008 on Labview 2012. I have windows 7, 64bits. I already see my DAQ on MAX. I installed two times the drivers and I tried on two similar PCs. None worked.
(3,635 Views)
