04-10-2008 10:56 AM
04-10-2008 04:15 PM
I noticed the same thing. Log sampling rates (in the Hz range) can result in odd spikes in the data.
I've personally worked around it by using a 1000Hz base sampling rate, then bunching the points together for an average.
04-11-2008 08:39 AM
Joe Friedchicken
NI Configuration Based Software Get with your fellow OS users
[ Linux ] [ macOS ]Principal Software Engineer :: Configuration Based Software
Senior Software Engineer :: Multifunction Instruments Applications Group (until May 2018)
Software Engineer :: Measurements RLP Group (until Mar 2014)
Applications Engineer :: High Speed Product Group (until Sep 2008)
