usb 6009
Hi  have  seen the  videos   Continuous Waveform Acquisition  using  usb 6211  generating and  acquiring   a signal on analog in and out .  I am unable  to  do the same using the 6009.  I suspect the  6009 cannot generate  waveforms . Am I  correct?
(2,896 Views)
USB-6009 can generate waveforms, but only in static software-timed (DAQmx_Val_OnDemand) mode.
Output voltage range is 0 - 5V; max. update rate is 150 Hz (very slow).
See the specification:
https://www.ni.com/docs/en-US/bundle/usb-6009-specs/page/specs.html
- George -
(2,885 Views)
Thanks  for your help . I will keep working on it
(2,864 Views)
