usb 6501 Not detecting
Dear all,
    I have been working with PCI DAQ,USB DAQ  for long time,but the USB DAQ 6501 is having some constant failures.The current issue that i am facing is that card is not getting detected in PC.So i feel glad if NI can support us in this regard.
Warm Regards,
Rajkumar
Development Engineer
(5,113 Views)
Hello Rajkumar,
Has this problem been reproduced with your device on another computer, or is this a problem with only one PC? Do other USB devices not detect on this computer? What kind of system are you running? What version of NI-DAQmx are you using? Does the problem occur when the computer boots up or will the device disppear after initially being connected? What do you have to do to reestablish connection the the USB-6501?
The answers to these questions would be very helpful in diagnosing exactly what is going on with your system.
Dan King
(5,105 Views)
Dear All,
   I tried to insert to usb card in many PC,but in none of the PC usb card was not detected.New harware wizard is als not coming.
So there is no response from PC.
We are using DAQmx Latest version.
(5,098 Views)
Thanks for the update, sorry to hear that your having trouble.  just to add my ideas..
The usb 6501 is bus powered - is the green power LED on at all?
Secondly, if you look in Windows Device Manger (Control Panel>>Systems..). Are any USB Devices listed?
Kind Regards,
James.
Kind Regards
James Hillman
Applications Engineer 2008 to 2009 National Instruments UK & Ireland
Loughborough University UK - 2006 to 2011
Remember Kudos those who help! 😉
(5,086 Views)
Dear Rajakumar,
Pleaes provide some inputs so that we would be able to tell you the cause and suggest some solutions.
With warm regards,
Pavan
(5,075 Views)
Dear all,
  Actually green light is glowing in USB,but its not detecting in PC,I tried to see in device manager for any usb hardware,but is for vain.
Warm regards,
Raj kumar
(5,073 Views)
Hi Raj,
Thanks for the update.
It seems like the device is working then.
Please could you try,
Use the Device Manager to scan for new hardware.
Follow these steps:
1. Click Start, and then click Run.
2. Type: Devmgmt.msc in the Open box, and then click OK.
3. On the Action menu, click Scan for hardware changes.
(This causes Windows to recognize new devices)
4. Close Device Manager and Control Panel.
Also, make sure Service Pack 2 for Windows XP is installed.
Could you please send a screenshoot of windows device manager to confirm the absence of the USB device.
You could also try,
Go to Start/Run, and type DEVMGMT.MSC , highlight the USB Root Hub device(s),
Action menu, "Uninstall", then restart Windows, to find the device drivers
again automatically.
Please let us know how you get on,
Kind Regards,
James.
Kind Regards
James Hillman
(5,063 Views)
