ā06-08-2010 02:40 AM
currently i need to aquire voltage signal from accelerometer through USB NI 6008 DAQ. i have created DAQ assistant in my VI. but when i click run, there is error occur. so can anyone please help me to identify my error. thanks
ā06-08-2010
06:57 AM
- last edited on
ā08-24-2026
04:52 PM
by
Content Cleaner
The error that you are seeing (-50103) is one of the most common DAQ errors. Take a look at this KnowledgeBase article, which explains the possible causes for this error. Case 6 is what you are seeing. You have two DAQ Assitants and are concurrently running two AI tasks. Consolidate to one task and acquire on multiple channels in the task if you want to.
Todd V
ā06-14-2010 10:15 AM
ā06-14-2010 11:27 AM
ā06-19-2010 11:31 AM
hi guys, i would like to ask how should i design my VI so when my analog port of USB6008 received 1V then my digital port will give out digital output for example in 4 bits 0001. then when the DAQ received 1.5V digital port wil give out 0010 for example.
ā06-20-2010 08:09 AM
ā06-20-2010 08:47 AM
hi there. do u have any sample for me to refer to. cause im still new in LabVIEW so i can't really get what you mean. hope u can help me. thanks
